Peugeot
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
Yicker-woody
Peugeot
Unread post by Yicker-woody »
Good morning People, I have a Peugeot 207 2010 1.6 HDi WA WC 112, the stereo cd wasn't working but everything else was. I got another head unit of ebay and got it vin coded it works, But now the bluetooth, AUX & USB Connection will not connect with the phone. The phones not the problem as it worked with the original head unit RD4/ RD45. As anybody got a answer for me? 🤔
Reason: Moved to the RD4 / RD45 Forum
x 6950
Re: Peugeot
It depends on whether you have bought an RD4 or an RD45 replacement unit - only the RD45 has built in Bluetooth. RD4 units are the basic ones and don't have built in bluetooth.
Yicker-woody
Re: Peugeot
Thanks, it's a Continental RD45 in the rear plug it's got the bluetooth wiring fitted and the wiring goes down to the centre console we're the USB &AUX is. Does it just need programming on the DigiBox?
x 6950
Re: Peugeot
Then if you have an RD45, it will need configuring with Diagbox. You may need to check some other settings too apart from VIN coding in case the unit has retained settings from or is missing correct configuration for your specific vehicle.
Yicker-woody
Re: Peugeot
Do you know of anyone who can do this in the St Helens Merseyside WA10 1GD, area.
x 6950
Re: Peugeot
Have a look at our list of members who have offered Lexia / Peugeot Planet / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
