C4 Split Cabin Heating
gosnoid72
(Donor 2022)
Unread post by gosnoid72 »
I have a 54 plate C4 VTS with split cabin heating (not sure if that's a standard thing). Today when driving home with the engine warm I had both sides set to low and the AUTO and A/C set to off. The temperature coming out of the vents above the stereo were completely different (very cool from the driver's side and very warm from the passenger side) Any ideas?
x 6950
Re: C4 Split Cabin Heating
Heater matrix / blockage or broken air mixing module gears on the air distribution or air mixing flap reduction motors.
You'd have to do some testing to see which by adjusting left and right side direction and and see the reaction, then the same for the temperature adjustment to help determine.
gosnoid72
(Donor 2022)
Thanks Marc, can you explain what you mean by left and right side direction adjustment? Is it a case of centre console out to gain access to the matrix?
x 6950
Pop your VIN up for me so I can see which system you have.
gosnoid72
(Donor 2022)
Will do. Just need to locate it!
x 6950
Outside lower portion of the passenger side windscreen in a cut out.
gosnoid72
(Donor 2022)
Thanks - VF7**************[VIN obfuscated, can be read by forum staff]
x 6950
Ok so you have the automatic bi-zone Air Conditioning system (with digital control panel). So what I was suggesting was to test the system out for temperature changes on each side and for air distribution on each side.
You need to get the car to operating temperature, then turn the A/C on with the engine running. Check the left and right side separately. Change the temperature to max heat and cycle the air distribution settings (screen, face, floor) and listen to see if you can hear the motors change the flaps inside the unit - check that the air moves to each of the the desired locations, but bear in mind it can take a few seconds for the motors to respond. Then change the temperature to the lowest setting and repeat, going from one air distribution setting to another.
Repeat this for the other side so you can determine if it is a motor distribution issue where the motor is not a) changing the air flow direction or b) bit mixing the air temperature on one side.
If the air motors seem to be operating ok, then you may well have a blocked heater matrix, which may need flushing through.
gosnoid72
(Donor 2022)
Thanks. Another job for the weekend then!
x 6950
Your sort of just trying to understand whether it is one of the motors that has failed or the gearing that operates the mixing flap which may have worn, or whether you need to get somebody to backflush the matrix for you and see if that unclogs it.
Sometimes this can be done with a hosepipe and use of the pipes as they enter the bulkhead from the engine compartment.
Maybe worth a watch:
gosnoid72
(Donor 2022)
Ok, got round to it tonight. To summarise, the driver's side behaves exactly as it should. the temperature adjusts, as set on the control and the direction of flow likewise. On the passenger side, the direction of flow responds correctly, but the temperature remains warm, regardless of the setting on the dial or the activation of the a/c.
gosnoid72
(Donor 2022)
Update - today I listened as I adjusted the temperature dials. On both occasions I could hear the motor working, but the passenger side one sounded distinctly different and had no effect on the temperature, so I'm thinking possible dodgy motor or gearing.......
gosnoid72
(Donor 2022)
So, the good news is that the heater matrix isn't blocked. More good news, is that the temperature control motor works fine.
Bad news is that the gear wheel on the heater box which controls the flap is sha@@ed. Two or three missing teeth. ??
x 1061
Unread post by wheeler »
Dont panic, there is a modification repair kit available for just this fault. You fit a toothed sleeve over the damaged gear then fit a little bracket over it before you fit the motor back on. It comes as a kit to do the temperature flaps & the distribution motor too.
The dealer part number is 1607044080 and its £27.19 inc VAT but there are plenty on ebay around the £25 mark.
gosnoid72
(Donor 2022)
Oooohh, lovely, thank you. Just ordered one.
