Location of crankshaft position sensor
Davcat
Unread post by Davcat »
Hi can anybody help I have a citroen c2 07 1.4 diesel and it will not start and dionostics says there is a crankshaft position sensor fault but I can not locate where it is
x 1506
Re: Location of crankshaft position sensor
Assuming it's the same as the 1.6 then it's behind the crank pulley, at about 7 o'clock when viewed end on.
Seems that it is, pic from a timing belt video:
Davcat
Hi si that not the crankshaft speed sensor
x 1506
One and the same, there isn't a separate sensor.
Davcat
Ok thanks but I was lead to believe that the position sensor was on the flywheel Bell housing but the starting motor but can not see it
x 6950
If it's the 1.4 HDi 70 then there is a camshaft position sensor:
... and a crankshaft position sensor (engine speed), which is the one you are probably referring to:
Davcat
But what the location of both please 9
x 1061
Unread post by wheeler »
The cam sensor is located at the top of the engine pointing at the cam pulley, the crank sensor location is shown in the picture already posted.
Davcat
Re: low current to crankshaft position sensor
Hi
I have changed the crankshaft position to now my reader is say low current to position sensor what could this be
x 1506
What code have you actually got? Where did the sensor come from?
