Thanks it's one of the 8 that is missing. Is there a way to secure them in place so they don't get loose gradually with the vibrations etc?
Looks like this one but different part number
https://www.ebay.co.uk/itm/304365739190 ... SwS7xheEJx
C5 X7 EGR Bolts
osx
- x 15
C5 X7 EGR Bolts
Reason: I moved this back into the technical out of parts
C5 X7 Exclusive 2.0 HDi Auto
Huskyxantia
- x 933
Re: C5 X7 EGR Bolts
These should hold if there tight enough maybe the egr coolant chamber bolt holes are partially worn ? Id not want to use lock tight as this are alloy going into alloy if you do choose to go that route remember these can snap if there done up to tight.osx wrote: 13 Mar 2022, 17:44 Thanks it's one of the 8 that is missing. Is there a way to secure them in place so they don't get loose gradually with the vibrations etc?
Husky.
osx
- x 15
Re: C5 X7 EGR Bolts
What's the recommended torque for these bolts?
Huskyxantia
- x 933
Re: Citroen and Peugeot Official Parts Requests
I used to do firm hand tightness someone on here should have the setting 12 foot pounds ? Not sure there abouts...
Husky.
- x 6950
Re: C5 X7 EGR Bolts
No, those are the incorrect bolts. Stick to the part number I have provided you with if this is the correct item - there are hundreds of bolts - all different diameters, sizes and threads and those are not correct in your link.osx wrote: 13 Mar 2022, 17:44 Thanks it's one of the 8 that is missing. Is there a way to secure them in place so they don't get loose gradually with the vibrations etc?
As for the torque:
The bolts (9) Tighten to 1 ± 0,1 daN.m
The bolts (11) Tighten to 1 ± 0,1 daN.m
Tighten the bolt (12) to 1 ± 0,1 daN.m.
Huskyxantia
- x 933
Re: C5 X7 EGR Bolts
Oops i said 12 newtons.. yes it is 10 newtons tops..
Becareful of the metal gasket if you plan to move the egr as they can fall then land where its hard to find.
Husky.
osx
- x 15
Re: C5 X7 EGR Bolts
I am concerned about where the missing bolt has gone.
Called the local dealer and they only sell them in a packet of 10.
- x 6950
Re: C5 X7 EGR Bolts
Yes, had that before when I wanted some clips - I had to buy a bag of 25 boot rings!
- x 1507
Re: C5 X7 EGR Bolts
Helpfully PSA give the details of the bolt in the part description, so you can get one elsewhere (much cheaper!)
8) MUL Flanged Screw Diam 6 x 100-60, Part: 101116, £2.15
Means it is M6 1.0mm thread pitch and 60mm long. If you've got one of the bolts in hand you should be able to see if it is a HT bolt (stamped 8.8 on the head), and also if it has a shoulder. Should be easy enough to find a supplier to match.
osx
- x 15
Re: C5 X7 EGR Bolts
That's what I thought but probably easier to buy them from the dealer and share the ones I don't need in the forum. I am sure they can be used in other areas.
osx
- x 15
Re: C5 X7 EGR Bolts
Any suggestions where I can buy a couple as the dealer hasn't been able to source them this week.RichardW wrote: 14 Mar 2022, 16:09 Helpfully PSA give the details of the bolt in the part description, so you can get one elsewhere (much cheaper!)
- x 8176
Re: C5 X7 EGR Bolts
Have a look at this company, They appear to have what you need:
https://www.ebay.co.uk/itm/181797191302 ... SwIMBhrnEk
You may have to ask if they have high tensile versions.
