Adaptive cruise control
Sotirios
Unread post by Sotirios »
Hi from Greece. I have Renault grand scenic automatic 7/2019 with Active Emergency Braking with pedestrian detection lane departure warning and lane keep assist , but with simple cruise control, can you tell me how I upgrade it to adaptive cruise control? Thanks
x 1943
Re: Adaptive cruise control
Unread post by Paul-R »
I don't think we have that level of expertise for Renault specifically but if the system is at all similar to that on PSA vehicles then it is really a viable option. You would need so many extra pieces (radar, possibly another ECU, possibly even a different main processing unit) that it would be too expensive.
x 6957
I think Paul meant to say was 'not really a viable option'.
Systems like this are heavily integrated into the vehicle at the factory and require the correct wiring harness, level of BSI, hardware and software. It's not something you can upgrade to.
x 1943
GiveMeABreak wrote: 09 Mar 2022, 13:46I think Paul meant to say was 'not really a viable option'.
Oops, certainly did.
Sotirios
My car has radar for the emergency brake and for the distance from the front car, this is radar and for adaptive. ECU only upgrade need not to change. Look this in Greece Delectronics.gr this is for VW ,Audi ,seat scoda .
x 6957
Some vehicles use a combination of radar and cameras, some just use cameras for some of the functions. But you will find it may be a different ECU version is needed and / or different equipment for the additional function.
