Partner HDI 2.0 van 2004 clutch wires !
DEVON DOGG
Unread post by DEVON DOGG »
Good Afternoon
Not been here for a while but still running French vehicles one of them a 19 plate boxer van with 160k on the clock on its second engine ! :x
I have just tightened up the 13 mm pivot nut on the clutch pedal I was wondering what are the wires /junction boxes on the clutch pedal
Many Thanks Jeremy
Huskyxantia
x 908
Re: Partner HDI 2.0 van 2004 clutch wires !
Unread post by Huskyxantia »
Any photos mate ? .. sensor for clutch adjustment ?
:-D
x 6957
Probably your clutch position sensor.
DEVON DOGG
Many Thanks
What is the purpose of this clutch position sensor it is an old skol cable system and I just cant fathom out what it could be doing
At the moment it is stuffed up under the dashboard and doing nothing and I have not noticed any difference
x 1056
Unread post by wheeler »
The engine ECU uses the clutch position information to make slight adjustments to the fueling when dipping the clutch for anti stalling. It also is used for cruise control operation if fitted.
You probably wouldn’t notice that much difference if it wasn’t working. I remember working on a petrol C3 that the clutch switch had came detached, it stalled really easily when pulling away, I suppose you would just ‘learn’ the clutch just like driving a different car.
DEVON DOGG
Thank you Wheeler
Nothing was broken I just moved them out the way and never put them back on a test drive as a courier vehicle I dont want it to drink anymore diesel. so I will probably refit them tomorrow
x 1943
Unread post by Paul-R »
wheeler wrote: 13 Jan 2022, 16:54... I suppose you would just ‘learn’ the clutch just like driving a different car.
In other words, learning to drive properly like we all had to do "in the olden days"!
