Citroen C4 VTS - 6445YA Sensor ?
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
HI,
Anyone knows what is the 6445YA sensor for ? I know it is related to the automatic air conditioning system ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1055
Re: Citroen C4 VTS - 6445YA Sensor ?
Unread post by wheeler »
Thats not coming up as a valid part number, do you have a picture?
x 3296
Wheeler, if you have access to the Citroen docbackup application I have found that sensor (item 3) is on page 0510 06 6443 01A.
x 6945
It's an old part number for the brightness sensor - no longer used (a new part number was used). It's the sensor that sits in the top centre of the dash board and works with the climate system to determine how intense / bright the sun is so it can adapt the flow of the air as needed. You may notice on a sunny day with the climate on auto, when you drive out of a bright sunny area into a shaded area, that the climate control alters the air flow direction and vice versa.
Later versions were a bit more advanced in that they determined the direction of the sunlight hitting the sensor so could make finer adjustments.
lancia58
(Donor 2022)
x 8
Is it still available from Citroen ?
x 6945
Yes but has a different part number.
Ask your dealer or see below if you require part numbers:
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
x 1055
Hell Razor5543 wrote: 08 Jan 2022, 10:03 Wheeler, if you have access to the Citroen docbackup application I have found that sensor (item 3) is on page 0510 06 6443 01A.
I was using the live servicebox & it doesn't show on that as pointed out its an old number. i can now see it on the doc backup version.
