2011 C4 PICASSO 1.6 HDI INJECTOR BOLT TORQUE
Pjbrady
Unread post by Pjbrady »
Hi all, my problem is not an uncommon one its a chuffing injector. Having entered all the relevent info on Ebay I ordered a seal kit, a very simple process I decided to do before dismantling the relevant parts.
Big mistake, after removing what seems to be every plastic and insulating piece from under the screen area followed by multiple pipes, connectors etc I was presented with mr/mrs/ms (best keep everybody happy) chuffy on the far left of the 4 injectors.
After the usual struggle the injector was removed with the familiar gak. It is at this point I realised there was no white spacer or oil seal for the injector just a straight fit into the head and of course the copper washer. At this point I realised I had ordered the wrong kit so I ordered 4 citroen washers and saving 3 for the future. My problem is finding a torque setting for the torx bolt? and do I renew the bolt?
The injector is a Continental and I am not confident with the info shared online.
Can anyone help?🤔
PJ.
x 1490
Re: 2011 C4 PICASSO 1.6 HDI INJECTOR BOLT TORQUE
Is it a 16v or 8v version?
Datadogie
x 8
Unread post by Datadogie »
IT's a low torque something like 4 but then you have to tighten it up another 60 degrees. And as for new bolts, new is preferred. Think of a copper wire, how do you break it if you don't have cutters? You keep bending it back and fore till it snaps. That's why you need new bolts.
