DS7
MG1959
DS7
Unread post by MG1959 »
Hello
Would anyone know how to alter the clock on my ds7 , can’t seem to find my way around
Mark
x 6956
Re: DS7
Hi
If you're referring to the physical clock that retracts, then it is synchronised directly with the time on the Touch Screen. So your system time on the touchscreen is probably out too in that case. Once you adjust the touch screen time, the clock will update too.
MG1959
Re: DS7
It’s the digital clock
x 6956
Re: DS7
Retractable Clock:
Touchscreen Clock:
In either case you need to go into the SETTINGS of the Touchscreen to change the time. It's all on page 41 or thereabouts of the owner's manual.
Note that you can only adjust the date and time if the 'Synchronisation with the GPS' option is deactivated.
