Hi John. Thanks for your Forum donation.
If it's item (4)
(4) Intake Filter Air Hose, part: 143437 (NFP - no longer available from Citroen).
If any other let me know the item number from the above.
- x 5807
Hi Marc
Yes thats the part thank you i will now try to source one online.
Kind regards
John
Kind regards
John
Hi Marc,
Could you please provide me the following oe numbers ?
1. Camshaft pulley bolt
2. Crankshaft timing belt pulley bolt
Also need to know the tightening torques for the same.
Thanks,
Bart
Thanks,
Bart
- x 5807
I'm going out for an hour, let me know which items.
Hi Marc,
1st one is item no:10
2nd item is not in this exploded view, it is the bolt that fits the lower auxilery belt pulley to the Crankshaft.
And i need to know the tightening torques for the 2 items.
Thanks,
Bart
Thanks,
Bart
- x 5807
If it's (9), Crankshaft Pulley Screw, part: 1682800780, £8.65
- x 20
Good morning! Could I have the part numbers for the front shock absorbers. I'm finding two different sizes of outer diameter for my car just need to make sure it's the right one
- x 5807
OEM Left, part: 5208H1, £88.48
OEM Right, part: 5208H2, £88.148
Cheaper Alternative Left, part: 1635532080, £81.04
Cheaper Alternative Right, part: 1635530880, £71.93
- Donor 2023
Citroen C5 X7 Estate 2012 VTR+ 1.6HDI 110 Wishbone Part nos.
Post by howardaskew » Sat Feb 24, 2024 1:27 pm
Good morning.
I am looking to change the wishbones on both sides of our 2012 C5 X7 Estate 1.6HDI VTR+ DV6C 110 VIN VF7**************[VIN obfuscated, can be read by forum staff]
Would I be correct in stating that the part numbers would be the same as our 2010 C5 X7 Saloon 2.0HDI VTR+163 VIN VF7**************[VIN obfuscated, can be read by forum staff]
I am reading that there are more than one type of wishbone, would I be correct that around 2010 they changed the part?
I am always grateful for any help received on this forum.
Good morning.
- Donor 2023
- x 378
Hi Marc,
Cannot edit my post to get the Vin and make a new post but could you have a look for what i believe is the indicator/wiper/ air bag assembly for the above Vin.
Has got issues with no indicators/lights and said something about the air bag as well.
If you can post the steering wheel assembly much appreciated.
Colin
- x 20
Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. CheersGiveMeABreak wrote: ↑22 Feb 2024, 11:28
(1) Front Damper
- x 5807
I need a VIN Colin - or tell me if it's the 2009 or 2010 X7 in your profile.admiral51 wrote: ↑24 Feb 2024, 13:45Hi Marc,
Colin
- x 5807
The Springs are on a separate diagram:
Let me know item numbers
- Donor 2023
C5 X7 Wishbones are there different types?
Good morning.
Good morning.
Reason: Post moved to the Parts thread
