- x 6953
Hi John. Thanks for your Forum donation.
If it's item (4)
(4) Intake Filter Air Hose, part: 143437 (NFP - no longer available from Citroen).
If any other let me know the item number from the above.
If it's item (4)
John77vts
Hi Marc
Yes thats the part thank you i will now try to source one online.
Kind regards
John
Kind regards
John
BVL
Hi Marc,
Could you please provide me the following oe numbers ?
1. Camshaft pulley bolt
2. Crankshaft timing belt pulley bolt
Also need to know the tightening torques for the same.
Thanks,
Bart
Thanks,
Bart
- x 6953
I'm going out for an hour, let me know which items.
BVL
Hi Marc,
1st one is item no:10
2nd item is not in this exploded view, it is the bolt that fits the lower auxilery belt pulley to the Crankshaft.
And i need to know the tightening torques for the 2 items.
Thanks,
Bart
Thanks,
Bart
- x 6953
(10) Camshaft Pulley Screw, part: 1682801980, £2.62
If it's (9), Crankshaft Pulley Screw, part: 1682800780, £8.65
BVL
dylan26__
- x 22
Good morning! Could I have the part numbers for the front shock absorbers. I'm finding two different sizes of outer diameter for my car just need to make sure it's the right one
- x 6953
(1) Front Damper
OEM Left, part: 5208H1, £88.48
OEM Right, part: 5208H2, £88.148
Cheaper Alternative Left, part: 1635532080, £81.04
Cheaper Alternative Right, part: 1635530880, £71.93
howardaskew
- x 9
Citroen C5 X7 Estate 2012 VTR+ 1.6HDI 110 Wishbone Part nos.
Post by howardaskew » Sat Feb 24, 2024 1:27 pm
Good morning.
I am looking to change the wishbones on both sides of our 2012 C5 X7 Estate 1.6HDI VTR+ DV6C 110 VIN VF7**************[VIN obfuscated, can be read by forum staff]
Would I be correct in stating that the part numbers would be the same as our 2010 C5 X7 Saloon 2.0HDI VTR+163 VIN VF7**************[VIN obfuscated, can be read by forum staff]
I am reading that there are more than one type of wishbone, would I be correct that around 2010 they changed the part?
I am always grateful for any help received on this forum.
Good morning.
admiral51
- (Donor 2026)
- x 391
Hi Marc,admiral51 wrote: 21 Dec 2023, 15:26 Hi Marc,
Could i have a part number for an engine oil dipstick for Vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] please. The yellow plastic puller has broken off.
thanks
Colin
Cannot edit my post to get the Vin and make a new post but could you have a look for what i believe is the indicator/wiper/ air bag assembly for the above Vin.
Has got issues with no indicators/lights and said something about the air bag as well.
If you can post the steering wheel assembly much appreciated.
Colin
dylan26__
- x 22
Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. CheersGiveMeABreak wrote: 22 Feb 2024, 11:28
(1) Front Damper
- x 6953
I need a VIN Colin - or tell me if it's the 2009 or 2010 X7 in your profile.admiral51 wrote: 24 Feb 2024, 13:45Hi Marc,admiral51 wrote: 21 Dec 2023, 15:26 Hi Marc,
thanks
Colin
Colin
- x 6953
The Springs are on a separate diagram:dylan26__ wrote: 24 Feb 2024, 17:12 Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. Cheers
Let me know item numbers
howardaskew
- x 9
C5 X7 Wishbones are there different types?
Good morning.
Good morning.
Reason: Post moved to the Parts thread
