405 vs xantia water pump
saeedm
x 16
Unread post by saeedm »
can i use peugeot 405 -XU7 JP/LFZ- water pump on xantia XU10 J4R RFV?
cos they are identical
x 1746
Re: 405 vs xantia water pump
Check out the part numbers. If the same, then ok.
As you know, if you need us to do that, you'll need to be a forum donor!
saeedm
x 16
the difference is impeller diameter.
xantia pump: 68mm
405 pump: 60mm
x 1746
Forum donation info here:
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
A donation will give you access to the Members' Area and Resources area of the forum (go to it via Board Index),
and to make Parts info requests during this year and next.
