C5 Wheel Nut Torque
PeeBee
(Donor 2021)
C5 Wheel Nut Torque
Unread post by PeeBee »
Hello All,
Could some kind person help with the wheel nut torque in ft lb (10da Newton?) for the alloy wheels on my C5 Mklll please?.
I have searched the forum and the supersticky and I am just going round and round and cant find an answer.
Steve Walsh
x 516
Re: C5 Wheel Nut Torque
Unread post by Steve Walsh »
74 ft/lbs on mine
x 6957
74Lbs!! I think you have the decimal out Steve. I wouldn't want that force on my alloy bolts! :-D
It should be 7.736 ft-lbs
Converter here for future reference:
https://www.omnicalculator.com/conversion/nm-to-ft-lb
Dormouse
x 696
Unread post by Dormouse »
x 5673
GiveMeABreak wrote: 15 Oct 2021, 20:57 74Lbs!! I think you have the decimal out Steve. I wouldn't want that force on my alloy bolts! :-D
Hells bells!
I had mine at 90 ft-lbs.
Got it from a Citroen handbook I believe.
x 3566
Ermmm.... 10da Newtons equates to 100 NM which equates to 74lb/ft*
*- near enough for government work :lol:
Steve Walsh
x 516
I could probably do 7.7 ft/lbs with my fingers :-D
Steve Walsh
x 516
Steve Walsh wrote: 16 Oct 2021, 08:27
Just tried it out of curiosity, 3.3 ft/lbs on a torque meter with my hands :-D
Dormouse
x 696
Steve Walsh wrote: 16 Oct 2021, 09:19
ie 3.3 ft/lbs Finger Tightness
7.7 ft/lbs 2 Fingered Tightness
Sorry in advance but I couldn't resist it - wheel tightness is a TIGHT 70 - 80 ft/lbs give or take
I admit I still think Imperial and still have to check Metric Conversions - easy boob to do given the plethora of differing units in use
Best advice I was given about tightness was " tighten it up until it breaks then turn it back half a turn" - if you kept breaking bolts you hadn't learned enough and didn't deserve to do the job on your own. If things kept coming slack you were sacked.
PeeBee
(Donor 2021)
Thanks Marc for that convertor, looks like Steve was spot on.
The finger tight setting was one obviously to avoid causing any damage to your alloys HaHa.
Paul
PeeBee
(Donor 2021)
That PDF was interesting Doormouse. If I interpreted it correctly the setting is 100nm except C5 up to 2008 or did it mean with the arrow pointing at 2008 to be 'From 2008'.
My year reg is June 2008 so I will take the general consensus that the setting is 100nm although I couldnt quite understand the indication in the PDF for the C5 which gives the setting as 100nm and then seems to indicate an exception for the C5 with an arrow followed by the year 2008 but no alternative is shown ?.
Dormouse
x 696
PeeBee wrote: 18 Oct 2021, 22:56 That PDF was interesting Doormouse. If I interpreted it correctly the setting is 100nm except C5 up to 2008 or did it mean with the arrow pointing at 2008 to be 'From 2008'.
I wouldn't take it as gospel but I think is reasonably ok
x 6957
Guys, the tightening Torques for both Steel Rims and Alloys on the C5 X7 is to tighten to 10 daNm.
The RESOURCES section lists all the torques for the braking systems and the wheels are listed in there. Just look at any of the X7 brake replacement guides I have put up and they are in there. :)
I.e.: viewtopic.php?t=69529
PeeBee
(Donor 2021)
Thanks for the guide Marc with the wheel nut settings.
I was also interested to see the procedure for rear brake pad replacement where an electric handbrake is fitted. Although the replacement of the pads isnt imminent I not that a Lexia is needed, which fortunately I have.
x 6957
Yes, it is required to put the EPB into maintenance mode, which releases and 'unhooks' the cables as it were to allow the pads to be changed properly.
Also very important that when the release procedure has been done after the car is correctly positioned for the work, that the battery is disconnected. The reason for this is that if the ignition is accidentally switched on, the EPB will start to try and engage the cables and could cause damage if you are not anticipating this. There is a reconnection procedure in the same place that ensures the cables re-engage properly after correct operation.
