Hi, any help or advice would be greatly appreciated.
My engine fan stopped working. A friend took a look for me.
I am left with multiple issues. Fan still not working, heater and air con not working, main beam and front washer jet not working, lights only go off when ignition turned off. Diagnostics show no fault.
Xsara Picasso 2007 Fan not working
- x 7934
Re: Xsara Picasso 2007 Fan not working
Hi Puzzled and
to the forum.
If I have read your post correctly its a good job you didn't get an enemy to look at it for you! As so many apparently unrelated things have gone awry I would suggest you check all your fuses and then carry out the BSI reset procedure which you will find listed in the Citroen part of the forum. Then post up a plea for assistance in the Citroen section called 'Xsara Picasso help needed' or similar and you will get responses from members with far more expertise than me. In the meantime checkout the other parts of the forum and join in wherever takes your fancy!
Dormouse
- x 696
Hi and welcome too. Were all the issues there from the start or have they grown in number as testing progressed?
Puzzled
Only since they looked at it
Dormouse
- x 696
ok. As Mick says, go to the bit marked "Board Index" and repeat your request under "Citroen". More experts will read that bit than "introductions". See you on Citroen shortly.
