Citroen c5 2.0 hdi cutting out
Bill c5
Unread post by Bill c5 »
Hi Guys
my c5 2.0 hdi 2009 keeps cutting out, comes up with fault code P0215, replaced the fuel regulator as rail pressure was also to high but it still keeps cutting out, wait a few minutes and restarts, also ESP fault has started coming on dash, any help would be much appreciated.
Thanks Bill
Dormouse
x 696
Re: Citroen c5 2.0 hdi cutting out
Unread post by Dormouse »
Hi Bill. There is a thread for this back in 2012. use the "search this topic" bar at the top of the page until someone (more knowledgeable) gets back to you. use "fault code P0215" in the search bar. cheers
x 6947
Here's the fault code descriptor:
Fault Code: P0215
Description of Fault: Supply relay control: Short circuit to earth or short circuit to positive or open circuit. Main relay stuck.
Conditions for Fault to clear: The following conditions have to be met:
- Engine idling (For several seconds)
- Engine cut following a phase in which the engine management ECU becomes dormant
Downgrade Modes whilst Fault is active: None Specified.
Symptoms: Starting problem
Suspect Areas:
  • Engine fuse box
  • Electrical harness
  • Connector
leithant
x 9
Unread post by leithant »
Given that you replaced the fuel rail sensor, it's possibly the fuel pump relay.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
Bill c5
Ok guys i changed the under bonnet fuse box no difference, it was getting worse now undrivable, new codes are
P1166
P0336
P0337
P1164
P0243
P1457
P0183
P1694 IS THE MOST POPULAR
im at my wits end with this
leithant
x 9
You need to check the fuel pump is coming on. Is the relay on the fusebox clicking on? Can you start it with some starter spray?
95 Peugeot 306 S16
Gregor
x 16
Unread post by Gregor »
P0336 and 337 indicate crankshaft pos sensor. Had same simptoms, changed that cheap sensor (cca. 15 EUR) and problem gone. Also check battery health. They cause all sorts of fake alarms.
Driving Citroen is a diagnose!
leithant
x 9
Yes, Crank sensor is another possibility that is fairly commeon and easy to fix.
95 Peugeot 306 S16
Bill c5
Hi guys
turned out to be the crank sensor .
thanks for the help
Gregor
x 16
I'm glad you fixed it!
