Dash-top display panel.
kirkbyman
Unread post by kirkbyman »
Hi, newby visit,I retired to Spain 5 years ago,just picked up a 2001 2:0 hdi C5, just noticed as it's dark that the display showing time/date is illuminated even with the central locking on.. I've no handbook to check if it's a settings issue, Greatly appreciate any advice... Ian.
x 1055
Re: Dash-top display panel.
Unread post by wheeler »
Does it have an aftermarket radio installed by any chance?
kirkbyman
Yes it does,new kenwood,not by myself though,only got it today... thanks for quick reply
x 1055
This is one of the common side effects of an incorrectly fitted aftermarket stereo. Can you disconnect it ?
kirkbyman
it's pitch dark now,i'll look in the morning, is there a connection i should check for ?? Ian.
x 1055
There will be 2 plugs going into the radio, disconnect both of them & switch the ignition off & lock the car, wait 3 minutes & unlock the car & check if the fault has corrected itself. If it has you need to get the stereo fitted properly. If the fault is still there carry out a BSI reset.
