I see there are two types of front wheel bearing for this car, does anyone know how I tell the difference between an abs and non abs one? Its a 2008.
Thanks.
X7 2008 front wheel bearing - abs?
- x 1240
- x 1493
Re: X7 2008 front wheel bearing - abs?
Only 1 listed on service.citroen, Peter - 335082 - I imagine all X7s have ABS. Presume this is a bearing with a magnetic track on one side for the ABS pick up - make sure you install it the right way round!!!
- x 6945
Yes, all X7s have ABS and ESP as standard.
- x 1240
Thanks Marc. Only just a few mention the bearing for use with abs most make no reference to it. I had never heard of it until I consulted ebay.
- x 6945
As Richard says, there's only the one type whether you have Hydractive 3+ suspension or Bed Springs.
- x 1240
They certainly all look the same. Thanks again.
