X7 2008 front wheel bearing - abs?
x 1240
Unread post by Peter.N. »
I see there are two types of front wheel bearing for this car, does anyone know how I tell the difference between an abs and non abs one? Its a 2008.
Thanks.
x 1496
Re: X7 2008 front wheel bearing - abs?
Only 1 listed on service.citroen, Peter - 335082 - I imagine all X7s have ABS. Presume this is a bearing with a magnetic track on one side for the ABS pick up - make sure you install it the right way round!!!
x 6947
Yes, all X7s have ABS and ESP as standard.
x 1240
Thanks Marc. Only just a few mention the bearing for use with abs most make no reference to it. I had never heard of it until I consulted ebay.
x 6947
As Richard says, there's only the one type whether you have Hydractive 3+ suspension or Bed Springs.
x 1240
They certainly all look the same. Thanks again.
