2014 508 2.0 HDI 163 Auto Antifreeze Drain/Fill
508Allure
x 5
Unread post by 508Allure »
Hello all,
Family member had the 508 at the garage this morning for an antifreeze drain/flush/fill and supplied 12L of premixed OAT antifreeze and 25L deionised water for flushing the system.
The 508 was collected earlier and on arriving home the antifreeze is below the minimum level, 25L of unused deionised water in the boot and they have only used 4 of the 12 litres of antifreeze.
The garage said the cooling system capacity is around 10L but they could only get 4L into the system and they weren't aware they had to use the deionised water. 😱 As it stands, it seems we have 4L of premixed with 6L or so of tap water, which is not good.
Anyone know the cooling capacity of the 508 163 HDI or can point me to the procedure for the drain/refill?
Not really sure what to suggest to the family member as my own trusted mechanic has sadly just retired, so I can't even recommend a good garage.
Thanks for any suggestions.
x 6958
Re: 2014 508 2.0 HDI 163 Auto Antifreeze Drain/Fill
The procedure is the same as most PSA vehicles and the procedure is already in the 'Resources' sections for donating members:
viewtopic.php?t=64036
This covers filling by gravity or vacuum and degassing.
To upgrade your membership, details are in the table below, which will also provide you to request official part numbers and part diagrams for up to 2 years if interested.
A response to your question by a Forum Admin requiring Parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Parts Information and VIN Numbers Click Here
Then just pop your VIN up so I can 100% check your vehicle is the same procedure.
