I've a 2016 (2005-2016 mk2 jumpy) Citroen dispatch 2.0hdi. When I bought it couple years back I had an issue whereby I could only lock the back door with the key as it didn't lock on the remote central locking fob. However the remote fob did unlock the rear door (and the other doors) fine. As it was only just 3 years old it went in to Citroen and they replaced (I believe) a relay in the bsi module, which solved the issue and all central locking worked fine.....untill now
As I need to likely sort this now at my own cost, does anyone have any knowledge of what I may need to change? I gather the module is under the steering wheel but wouldn't know which relay needs switching out that controls central locking?
Any help or advice much appreciated guys
