Directional headlamp fault
Mase89
Unread post by Mase89 »
Hi
Lady owner DS4 62PLATE 2.0 hDI
Basically when my headlamp settings are set to auto on my stick. In the day I have no issues no errors.
As soon as it's starts to go dark or I go under a bridge the car senses it's darker and I get the following flash up "directional headlamp fault" and the headlight symbol starts to flash on my dash and does not disappear.
My lights seem to be working fine as in the evening when it's dark they are on once the fault comes up once the headlamp symbol just flashes.
I've read a few post but nothing helping just confusing me even more.
Any help is appreciated.
x 6950
Re: Directional headlamp fault
Hi and welcome.
What you'll find is that if you have directional headlamps, they will have a levelling system inside the units to make sure they don't dazzle oncoming drivers as they'll be Bi-Xenon directional lamps.
When the headlamps are activated, the headlamp ECU goes through a self-test to make sure the motorised units in each headlamp are operating properly. If they don't complete the check correctly a message will come up as you have described and the headlamp warning light will flash. This essentially means that the directional function of the lamps is disabled, leaving you with a standard static lamp that does not move. So the same applies even if you go under a bridge in the daytime - anything where it is dark enough to activate the headlamps - the same warning will be triggered.
So your headlamps will work, but they just won't provide the directional turning function until the fault is corrected.
It is possible that one of the motors has failed, or could be an electrical connection, so it needs some investigation.
Mase89
Thank you Marc. I'll have to take it to a garage as I wouldn't know where to start with the electrical connection bit. Do you know where the motors will be located ?
