Hello ,
i connect OBD ELM327 to my car and got the error codes : C0701 , P0420 .
i have to say that over few month i feel during a driving that the car / engine is slightly strangled and it means that the car have "little jumps" .
Also the vehicle smokes white smoke, from what I understand it is a faulty valve cap / rubber worn valves.
Does someone have a clue regarding the above mentioned error codes ? what it means / solutions ?
Thanks a lot .
C4 GRAND PICASSO MK2 2014 - C0701 , P0420 ERROR CODES
- x 6950
Re: C4 GRAND PICASSO MK2 2014 - C0701 , P0420 ERROR CODES
P0420 is to do with the Pre-catalyser (Efficiency too low): Internal fault, so may need further investigation / replacing.
Not sure about C0701 - I think that had something to do with the air inflator on the exclusive models, but I have no other info than that.
