hi,
my wife has a ds3 1.6 diesel. the car drives fine but won't rev over a certain amount (so mainly this is an issue for overtaking) on the computer screen it keeps flashing up with something to do with fault , take it to a garage . she has to just click the screen every time to dismiss it. we had a local garage plug it in and ran diagnostics on it. The mechanic was unsure. The service light on the dash is also illiminated. Could the computer be at fault or is one of these codes causing it. The picture attached is the faults. There is also sometimes an issue where we fill the car with ad blue and sometimes it still thinks it requires some more ad blue, but not sure if this is related? any help is much appreciated.
ds3 won't rev much above 2-3k revs - fault codes
peter789456
- x 3283
Re: ds3 won't rev much above 2-3k revs - fault codes
While I cannot offer any useful advice, might I suggest you type the vehicle VIN here? This will allow Forum staff (I am NOT Forum staff) to get more detailed information on your vehicle (provided the relevant manufacturer has granted the Forum staff access to their data). The Forum software will, for security reasons, obscure it so only Forum staff can read it (like this; VF7**************[VIN obfuscated, can be read by forum staff] ). Please do not put any spaces in the VIN, or post up any photographs of it, as the software will not recognise and protect it.
I would say that the top three codes do look rather 'interesting'.
- x 1465
Not sure any of those codes would result in limp mode, might need to re-scan it with an alternative tool! Does the light come on when you accelerate? It could be the fuel filter if it's not been changed, although these have a low pressure pump, so not that likely.
The ad blue thing might be the harbinger of something expensive unfortunately...the early ones have trouble with the adblue leaking into the electronics and wrecking them, trouble is it's only available as a complete unit with the tank costing about a grand!
peter789456
The VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
peter789456
its fairly random to be honnest - you can be driving then 10 minutes into your journey the notice on the computer comes on and so the the service light on the dashboard.
Someone recently suggested the DPF, what do you think? could be worth getting the fuel filter replaced then?
thank you
thank you
