Daughter has a 207HDI that has thrown up the usual (visit garage to fix fault) she popped into her local repairer this morning they stuck their diagnostic machine on it and popped up C322h-49954
1434H-5172 and U1218 not sure if the first two are proper ones but that is what she was given.
She has had the Eolys topped up a few weeks ago I have to assume the garage reset the counter when they filled the tank, but talking to daughter about cars is a non starter. For years I have always sorted out her car re repairs oil brakes etc but age and health problems have curtailed this. She lives in Basingstoke so not around the corner.
Car has done about 140000 miles Vin is VF3**************[VIN obfuscated, can be read by forum staff] as given by her. Would appreciate any clues what these errors mean and if it can sort it out for that would be great.
207 hdi error code
civvie
- x 21
207 hdi error code
Steve
C5 2.2hdi auto until I sell it (sold it) now have Peugeot 3008 1.6HDI (Now sold)
Had the jab a couple of days ago. Feb 21
civvie
- x 21
Re: 207 hdi error code
I assume non of the codes are valid then.
Steve
nikeastwood
- x 24
codes usually start with a "P"
a cheap OBD2 reader on ebay will get you some proper codes, probably for half the price it cost to take to a garage
no egr, no dpf, no problems.
- x 6955
Hi Steve, sorry, only just seen this.
The first 2 codes are not codes.
U1218 is a communication fault, usually on the CAN network. I’ll have more info on thus as it relates to your car when I get back in.
civvie
- x 21
Thanks Marc, will await any help you can give.
Nick, I didn't think those first two were proper codes, even the garage told my daughter they had never seen them before. She is going to look at her options as she knows it will cost her more money in the future and as she is in the care industry so needs reliable transport.
Steve
- x 6955
Ok, sorry I was a bit late getting back - Mother's Birthday today so duty chef!
This is the full fault code info:
| Fault Code: | U1218 |
| Description of Fault: | Intersystems CAN: One of the parameters present in a datastream sent by the BSI is invalid. Faults in communication between ECUs on the CAN. Fault is active when at least one of the following conditions must be fulfilled - Ignition switched on - Engine running |
| Conditions for Fault to clear: | Driving for 5 minutes |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
- x 3300
Wish "Happy Birthday" to your Mother from the FCF.
civvie
- x 21
Happy birthday mum.
Marc thanks for the info
Steve
civvie
- x 21
Am going to check the ECU connectors, Marc can you please guide me where the thing is placed on her car. Will do the usual checking tightness of the plug and clean the pins with switch cleaner. AFTER disconnecting the battery and letting it sleep.
Steve
- x 6955
The Engine ECU is on the left side of the battery. Be very careful with this, and despite what the bloke in the video says, if you are removing any connections from any ECU, always disconnect the battery terminals first and make sure they don't re-attach accidentally, following the BSI Reset / Battery Disconnect / Reconnect Procedure.
This vide will show you where it is:
civvie
- x 21
Thank you sir.
Steve
