rt6 software/firmware upgrade
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
skragamuffin
Unread post by skragamuffin »
hi all i have a C4 hatch with rt6 sat nav built in software version RNEG2.20.E.5 i want to upgrade this to the latest version possible without causing any issues i have read that 2.86 can cause issues with resetting the whole system and echo on the bluetooth system. so i was wondering if anyone could please give me any advice on this and maybee even supply the files for me to update the system if so i also believe that the code can be generated from the vin code using a bit of java script i would like the highest firmware update for 2 reasons for my own personal minds state and the fact i want postcode searching
thanks for reading
Paul
x 6957
Re: rt6 software/firmware upgrade
I think you may be confused Paul. Firmware updates need no VIN or codes or javascript. I think you may be getting mixed up with the Map Updates specifically that require a licence file.
Firmware does not need a licence file and is a straight update with the caveat that yes, some updates, notably V2.86 can reset the RT6 to default values, losing the configuration, which can affect functionality. This depends an a larger extent on the firmware version that you are updating from. I believe that early versions pose a higher risk of this happening.
My personal advice would be to get the dealer to do it for you. Although the software CD only costs about £10, it may cost you an hour of diagnostic time for them to apply the update, but at least if things go toes up they will be obligated to fix it. Just make sure you get them to confirm the system is fully operational and functional beforehand.
The risk of applying firmware from the USB or a copied CD is that the files may be corrupt in transfer. A genuine software CD from Citroen will be intact.
skragamuffin
thank you
