Interchangeability of front springs..?
Guy D Pearson
Unread post by Guy D Pearson »
Hi. Looking for a bit of advice... Have set about replacing the front coil springs on my 2006 Peugeot Partner MPV - when I check out replacement springs online (using the vehicle reg) I am generally getting two options - for vehicles with/without A/C... my vehicle has A/C but the existing springs are different to the image for the A/C version and identical to the non-A/C replacements..! How important is it that I use the right ones - are they interchangeable..? Thanks. Guy
x 3302
Re: Interchangeability of front springs..?
Hi, and :welc: to the forum.
The A/C system will add weight to the car, so the springs will need to be stronger to handle that increase in weight.
x 6955
There are different types of struts depending on engine and whether you have heavy rated suspension or not,
We can help with Official live Peugeot part numbers, but do ask for a Forum donation for this info as it is chargeable now by PSA. It will cover you for up to 2 years of Parts Info and Parts Diagrams, so good value. Details below, and if you want to proceed, just pop your VIN up after following the links.
A response to your question by a Forum Admin requiring Parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Parts Information and VIN Numbers Click Here
Guy D Pearson
Thanks, both, for helpful replies...
