2011 C4 GP scuttle drain location?
Michel
Unread post by Michel »
Could one of you kind folk please tell me where the scuttle drains on the C4 GP are? One of mine is clearly blocked, I can hear water sloshing about after heavy rain when I set off, and then as I go round the uphill left hand bend near here it all pours out of the unblocked one and leaves a trail behind me.
Thanks!
x 3306
Re: 2011 C4 GP scuttle drain location?
Don't forget that (once somebody lets you know where the drains are) the plumbers snake is in the C5.
x 1488
Pop the wing liner out behind the wheel and reach up behind and you will feel a short square tube with a flap on the end, it just pulls out of the body. And about a gallon of cold murky water is now running down your arm🤣
Michel
Thanks Richard, though it doesn't matter now...
