Could one of you kind folk please tell me where the scuttle drains on the C4 GP are? One of mine is clearly blocked, I can hear water sloshing about after heavy rain when I set off, and then as I go round the uphill left hand bend near here it all pours out of the unblocked one and leaves a trail behind me.
Thanks!
2011 C4 GP scuttle drain location?
- x 3296
Re: 2011 C4 GP scuttle drain location?
Don't forget that (once somebody lets you know where the drains are) the plumbers snake is in the C5.
- x 1488
Pop the wing liner out behind the wheel and reach up behind and you will feel a short square tube with a flap on the end, it just pulls out of the body. And about a gallon of cold murky water is now running down your arm
