I'm not so sure removing the cat was wise - if you are using dual fuel it may still be a requirement to pass the inspection - even in Turkey. So I can't help you with that - and would suggest you put it back.
I think you have a wider problem with something you've done - especially on the CAN network. A lot of these codes are related to CAN communications, so my question would be have you made any wiring modifications to the vehicle / cut any connections or anything like that? If you've cut any CAN wires you will have lots of problems as the various ECUs won't be able to communicate along the data network.
U1003: CAN communication fault (Missing/interference): No signal / Automatic transmission control unit: Mute
Fault will disappear when the CAN bus is active again.
Symptoms: Lack of power, Deactivation of the speed limiter, Deactivation of the cruise control, Difficult/impossible to change a gear.
Downgrade Modes Whilst Fault is Active: Absence of pressure regulation, No lock-up control, Absence of control of Neutral when cold (Absence of engine starting assistance in low temperatures), Control: Flow control solenoid in the exchanger (According to turbine speed), Coolant temperature = The oil temperature, Absence of autoadaptation for the controlled sliding of the converter, No engine management ECU switch to dormant mode phase (Complete switching off of the networks), No management by the ESP, Change from position N to a forward gear impossible, Change from position N to a reverse gear impossible, Absence of detection of locking of wheels.
Suspects: Main harness, Automatic transmission control unit, Built-in systems interface.
U2000: CAN network: Main wake-up fault - Main wake-up status absent (CAN information absent and/or invalid request sent by the BSI).
Downgrade Mode: The engine ECU changes to "down-grade principal wake-up" mode.
Suspects: Built-in systems interface, Engine ECU
U2118: Same as above: Detection of an anomaly on the request for partial wake-up status (CAN network disconnected; Short-circuit on the CAN High/CAN Low line; Loss of information on the CAN network).
Down Grade Modes: Exit from partial wake-up and change to transitory mode, Change to internal partial mode followed by extinction of the engine ECU (Provided no new request for wake-up of the BSI has appeared).
U1318: CAN network: Communication fault with the BSI ECU. Loss of a certain number of consecutive safety values sent by the BSI (Battery charge status; Battery temperature; Type alternator control).
Fault Triggering: The following conditions have to be met:
- - Presence of a BSI
- - No CAN fault on the engine management ECU
- - Engine management ECU in "main triggering" or "down-grade main triggering" phase
Suspects: Engine ECU, Built-in systems interface.
P0420: Catalytic converter: Loss of effectiveness. Catalytic converter ageing: Catalytic converter oxygen storage capacity value less than a threshold (For 6 test cycles).
You know why this fault is showing - given you have removed the cat...
Downgrade Modes: Transition to open loop of the downstream regulation' Deactivation of the canister purge function.
Symptoms: Emissions outside the norms, Reduction in engine performance
Suspect: Catalytic Converter
C1510: Fault Not Characterised.
U1318: Fault absence of communication with the built-in systems interface: No signal. Incoherent data coming from the built-in systems interface, so basically all extra functions (Hill Start / Auto mode) of parking brake are none-operational.
Suspects: CAN Network. ESP ECU, BSI
P1167: Pressure regulation fault (Difference / reference value): Not characterised. Pressure fault with a gear engaged (Excessive pressure error or the autoadaptive correction is saturated).
Symptoms: Lack of power, Deactivation of the cruise control, Deactivation of the speed limiter, Difficult/impossible to change a gear, Leaks.
Down Grade Mdes: Refuge mode, Line pressure forced to 21 bars, No declutching on stopping.
Suspects: Automatic gearbox (BVA), Electrohydraulic block, Fluid level, Electrical harness of the hydraulic valve block,
Main harness, Oil pressure sensor, Automatic transmission control unit.
Audio / RD5
B1501 / B1502: Basically, short circuit to either earth or positive - though there are 2 digits missing from the end to I can't tell you which it is. (B1501
11 - Earth or
12 Positive)
Same for B1502
The U1F1A is a short circuit on the LIN 1 network.
So most of these issues are related to the electrics - whatever has been done when you decatted / installed the LPG has had an adverse condition on the vehicle operation. So assuming none of the ECUs have been fried, I suggest you start retracing steps and checking all electrical connections - especially to the BSI.
