Complete Wiring diagram RNEG
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
Sonnic2000
Unread post by Sonnic2000 »
Hi guys,
does anyone have the wiring diagram of the RNEG? ...I want to know what the pins of the folding screen are for...
x 6945
Re: Complete Wiring diagram RNEG
Pins 9 & 11, 14 & 15:
Part "A": 16 way connector
Channel numberAllocation of channels of connector
1signal : Right hand rear speaker
2signal : Front right hand speaker
3signal : Front left hand speaker
4signal : Rear left loudspeaker
5Earth : Right hand rear speaker
6Earth : Front right hand speaker
7Earth : Front left hand speaker
8Earth : Rear left loudspeaker
9Supply : Retractable multifunction screen DEV
10Comfort CAN High
11Retractable multifunction screen position return signal DEV
12Battery + supply
13Comfort CAN Low
14Opening : Retractable multifunction screen DEV
15Earth : Retractable multifunction screen DEV
16Earth
Sonnic2000
Hi, i mean the flipscreen connector (d) .
I thinking this one is the Part A, B en C ...not the D connector
x 6945
That is for the LVDS connection to the Multi Function Screen:
Application: 10-way black connector
TerminalAllocation of channels of connector
1Clock LVDS CLK1 +
2Clock LVDS CLK1 -
3-
4Channel LVDS A0 +
5Channel LVDS A0 -
6Channel LVDS A2 +
7Channel LVDS A2 -
8-
9Channel LVDS A1 +
10Channel LVDS A1 -
Sonnic2000
Thanks for your attachment, but I see now that it's not really clear to me what the names mean. I was hoping to find out the video channel.
x 6945
The LVDS is the video input to the screen. The channels are for the different video and info data streams IIRC.
Bl3sS
Unread post by Bl3sS »
Can you post the complete wiring for parts B and C?
Im installing a bluetooth module directly into the radio instead of the aux connector which I never used. I swapped pins for left, right and earth audio, pins 4, 10 and 11 in parr B but I dont know if there is a pin for power supply. It'd be very usefull.
Thank you so much.
x 6945
Part "B": 12 way connector
1Earth : CD player
2VAN Low : CD player
3Permanent + : CD player
4Left audio system : CD player
5-
6-
7CAN High : CD player
8Earth : CD player
9-
10Left audio system : CD player
11-
12-
Part "C": 12-way black connector (Only with CD changer)
1Earth : CD player
5-
6-
8Earth : CD player
9-
11-
12-
Bl3sS
Thank you so much GiveMeABreak
A friend of mine contacted me to ask if I could do the same in his peugeot3008, he has the WIPNAV navigator.
Would you be so kind to post the wiring of this navigator?
I need the same as the other one, a power supply connection, ground, and aux.
Thank you so much!!!
x 6945
This is the WIPNAV system I have provided above.
Are you sure he doesn't have another system like WIPNAV+ or WIPCOM 3D?
If he's not sure, best to pop his VIN up.
Bl3sS
Ok, it's the same as mine, i though they were different. He has no usb in the aux, and the main unit has a sd card slot, so it's a normal wipnav. If I'm not wrong... xD
One question, the channel numers with "-", is there any way to know what they can be used for? Or are they just blank connectors with no use at all?
x 6945
They are not used and therefore are useless as they don't connect to anything.
maximgranovskiy
Unread post by maximgranovskiy »
Can someone help with display? I need a pins end what it doing. Its RNEG MyWay with SD Card
