Hi guys,
does anyone have the wiring diagram of the RNEG? ...I want to know what the pins of the folding screen are for...
Complete Wiring diagram RNEG
Moderator: GiveMeABreak
- My Cars: Peugeot 308 CC
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: Complete Wiring diagram RNEG
Pins 9 & 11, 14 & 15:
Part "A": 16 way connector
Channel number | Allocation of channels of connector |
1 | signal : Right hand rear speaker |
2 | signal : Front right hand speaker |
3 | signal : Front left hand speaker |
4 | signal : Rear left loudspeaker |
5 | Earth : Right hand rear speaker |
6 | Earth : Front right hand speaker |
7 | Earth : Front left hand speaker |
8 | Earth : Rear left loudspeaker |
9 | Supply : Retractable multifunction screen DEV |
10 | Comfort CAN High |
11 | Retractable multifunction screen position return signal DEV |
12 | Battery + supply |
13 | Comfort CAN Low |
14 | Opening : Retractable multifunction screen DEV |
15 | Earth : Retractable multifunction screen DEV |
16 | Earth |
Hi, i mean the flipscreen connector (d) .
I thinking this one is the Part A, B en C ...not the D connector
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That is for the LVDS connection to the Multi Function Screen:
Application: 10-way black connector
Terminal | Allocation of channels of connector |
1 | Clock LVDS CLK1 + |
2 | Clock LVDS CLK1 - |
3 | - |
4 | Channel LVDS A0 + |
5 | Channel LVDS A0 - |
6 | Channel LVDS A2 + |
7 | Channel LVDS A2 - |
8 | - |
9 | Channel LVDS A1 + |
10 | Channel LVDS A1 - |
Thanks for your attachment, but I see now that it's not really clear to me what the names mean. I was hoping to find out the video channel.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The LVDS is the video input to the screen. The channels are for the different video and info data streams IIRC.
Can you post the complete wiring for parts B and C?
Im installing a bluetooth module directly into the radio instead of the aux connector which I never used. I swapped pins for left, right and earth audio, pins 4, 10 and 11 in parr B but I dont know if there is a pin for power supply. It'd be very usefull.
Thank you so much.
Thank you so much.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Part "B": 12 way connector
Part "C": 12-way black connector (Only with CD changer)
1 | Earth : CD player |
2 | VAN Low : CD player |
3 | Permanent + : CD player |
4 | Left audio system : CD player |
5 | - |
6 | - |
7 | CAN High : CD player |
8 | Earth : CD player |
9 | - |
10 | Left audio system : CD player |
11 | - |
12 | - |
5 | - |
6 | - |
9 | - |
11 | - |
12 | - |
Thank you so much GiveMeABreak
A friend of mine contacted me to ask if I could do the same in his peugeot3008, he has the WIPNAV navigator.
Would you be so kind to post the wiring of this navigator?
I need the same as the other one, a power supply connection, ground, and aux.
Thank you so much!!!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
This is the WIPNAV system I have provided above.
Are you sure he doesn't have another system like WIPNAV+ or WIPCOM 3D?
If he's not sure, best to pop his VIN up.
Ok, it's the same as mine, i though they were different. He has no usb in the aux, and the main unit has a sd card slot, so it's a normal wipnav. If I'm not wrong... xD
One question, the channel numers with "-", is there any way to know what they can be used for? Or are they just blank connectors with no use at all?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
They are not used and therefore are useless as they don't connect to anything.
