2012 1.6hdi P0405 fault egr changed
4d1lr
Unread post by 4d1lr »
Hi peeps, I'm having a problem with my car going into limp mode with p0405 have changed the egr valve and still no joy this code happened after the egr valve had been changed prior to that I was getting p3007. Any help would be appreciated. Also where can I get a proper scan tool/software for Peugoet. Is it the Planet or diagbox I need. Thanks
x 6957
Re: 2012 1.6hdi P0405 fault egr changed
I think you do actually need to do some further investigation as P0405 relates to the Electric EGR valve repeat signal fault: Copy voltage too low. So there is the possibility of the supply voltage or depending on your engine may need some terminal boxes to properly troubleshoot and eliminate certain components / connections.
If you have the VIN, pop that up (automasked on post submission) that would help determine the exact engine and ECU you have.
4d1lr
Vin
It is a 1.6hdi 2012 with dpf
x 6957
Ok, so you actually have a 2011 model (built 7th September 2011), so was a late registered vehicle with 1.6 HDi 92 (DV6DTED) engine and Bosch Injection.
So ignore the preovious fault - as you can see it is slightly different for this vehicle. In your case, the P0405 Fault states:
Fault Code: P0405
Description of Fault: Measurement of the position of the EGR valve: Open circuit or short circuit to earth. Voltage less than 0.3 V for 500 ms
Conditions for Fault to clear: Driving for 5 minutes
Downgrade Modes whilst Fault is active:Forced regeneration via the Diagnostic tool is prohibited whilst this fault is active. Management Info Light is also on when fault is active.
Symptoms:
  • Noise
  • Slightly higher fuel consumption
  • Smoke from the exhaust
  • Absence of automatic stopping of the internal combustion engine (Vehicle equipped with "stop and start")
Suspect Areas:
  • Exhaust gas recycling valve
  • Electrical harness
  • Connectors
So I would be checking the electrical side, as the EGR is not getting enough voltage. Check the electrical connections to the EGR - especially the pins in the connector to make sure they are not loose.
4d1lr
Thank you very much for your reply. Do you recommend using a electrical cleaner. I also change the sensor near the actuator. Seems like a possible problem with the harness or plugs.
x 1459
Unread post by xantia_v6 »
Did you fit a new genuine valve, or a used or aftermarket part? It is possible that the valve is not compatible.
4d1lr
I fitted a new one but don't think it was oem one. However I have now fitted 2 new ones
civvie
x 21
Unread post by civvie »
Did you by any chance get them from Euro Car Parts
Steve
C5 2.2hdi auto until I sell it (sold it) now have Peugeot 3008 1.6HDI (Now sold)
Had the jab a couple of days ago. Feb 21
