Apologies firstly if I shouldn't be asking this. I only joined the other day:
I've put a deposit on a 2012 2.0HDi C5 Tourer in silver and before I transfer the balance I'd like to check the VIN.
The usual free/dodgy sites either don't come back with anything, or one came back with a white 1.6 saloon!
Is it possible to get a build sheet of this car? I have donated to the forum.
The VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Thanks,
Niall
Citroen C5 Build sheet from VIN?
Sebastian Tombs
- (Donor 2021)
- x 1055
Re: Citroen C5 Build sheet from VIN?
Not sure how this will come out as a copy & paste but here goes.
C5 (X7) 5 DOOR ESTATE 2.0 HDi 163 PEF (DW10CTED4) 6-SPEED AUTOMATIC GEARBOX DAM : 12603CJ
Vehicle family C5 (X7)
AS/RP N° 12603 CJ 1 0848
Warranty Start Date 20/02/2012
Engine serial number 10 DYYG 4024417
OPB HBDA
BER e2*2001/116*0360*19
P4A 9665460399
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 (X7)
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL UPPER LOW PLUS
ENGINE DW10CTED4 FAP TURBO DIESEL
TRANSMISSION 6-SPEED AUTOMATIC GEARBOX
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPE W&W LEATHER ST CYR + LEATHER "XS"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) BVA AM6C1
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " EXCLUSIVE
BADGE C5
Vehicle characteristics
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 5 L6 UPPER ENGINE EMISSION CONTROL
EXHAUST LONGITUDINAL REAR SILENCER
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER LESS THAN 10PPM
FUEL TANK FUEL TANK WITH LOCATING TAB
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) POWER 120 KW 340 NM
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 ELECTRONIC FAN WITH INTEGRATED CONTROL 220W
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIO CP 15 X 53
WHEEL STYLE IONIENNE2 "17-INCH" STYLE WHEEL
CLUTCH WITHOUT CLUTCH
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
RIM/TYRE SIZE 17 INCH TYRE FITMENT
TYRE (SIZE, TYPE) TYRE 225/55 R17 97W NON-REINFORCED
WHEEL (TYPE) IONNIENNE 17" ALLOY WHEEL RIM
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE Auto gearbox AM6
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24,5
STEERING TRAVEL 180 STEERING MECHANISM TRAVEL
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION ACTIVE SUSPENSION MANUAL ADJUSTMENT
SUSPENSION (ARCHITECTURE TYPE) HYDRAULIC SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
Body fittings
SIDE MOULDINGS (TYPE) CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) PLASTIC + CHROME SIDE PROTECTORS
EXHAUST TAILPIPE NON CHROME PLATED EXHAUST TAIL PIPE
SILL ILLUMINATION LAMP SILL LIGHT FRONT AND REAR
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR ELECTRIC-FOLD BACK
WINDSCREEN WIPER FRONT WIPER AUTO SPEED 16 SPEED
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER HEADLAMP WASHWIPE
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COL BUMPER + CHROME PROT + CHROME GRILLE TRIM
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE) TINTED EXT REAR VIEW MIRROR
EXTERIOR ACCESSORIES CHROME EFFECT EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) DEEP TINTED WINDOW
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITH REAR ARMREST
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT PALEA METAL DECOR
MISC. INT. LAMPS SOFT AMBIANCE LIGHTING
LOAD SPACE TRIM CARPET+MOULDING AND CHROMED HANDLE
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIM GLOSS ARGENT BLACK DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT REAR ADJUSTMENT SPACER
DRIVER SEAT CONTROL MEMORY CTRL DRIVERS FRONT SEAT
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT ELEC CNTRL
FRONT SEAT ARMREST (OPERATION) FRONT ARMREST MANUAL
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS DISCHARGE BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY DISPLAY DG4
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMP WITH DIRECTIONAL LIGHTS
RADIO RECEIVER 4TH GENERATION "NG4" RADIO NAVE SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS WITHOUT SIDE BLINDS
TRIM ADAPTATION LEATHER GEAR LEVER KNOB + LEATHER GAITER
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL 4 BRANCH LEATHER STEER WHEEL DECOR METAL
SEAT LUMBAR SUPPORT (OPERATION) AUTOMATIC LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET 1 AUDIO RCA SOCKET
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L3 500
STARTER MOTOR STARTER MOTOR CLASS 6+
SPECIAL LIGHTING FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
LABEL WITHOUT
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
OPB HBDA
P4A 9665460399
General information
ENGINE (TYPE) EW/DW
BADGE C5
Fuel supply-Engine
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
Body fittings
SUN ROOF FIXED ROOF
Interior fittings
DISPLAY DISPLAY DG4
Electrical
Miscellaneous
LABEL WITHOUT
Sebastian Tombs
- (Donor 2021)
Thank you so much!
That accurately matches the car, which has put my mind at rest.
I guess we shall pay for it now then!
- x 3296
Hi, and
to the Forum. Do not worry about asking questions within a few 'moments' of joining; the primary reason this Forum exists is to HELP people with problems with their French cars (not to hinder them by being derisive of new members). There are other parts of the Forum where members have fun, so do feel free to browse.
catalinos
Can anyone help decode my vin? VF7**************[VIN obfuscated, can be read by forum staff]
- x 6945
@catalinos:
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
