Hey, my citroen saxo has ignition key sticking issues lately, i tried to clean it and lubricate it but after abit problem comes back... now i want to replace it with a brand new one, my car is a 1.5D it has immobilizer with bosch pump but it has no ECU
If i swap the ignition barrel, and i keep the same immobilizer ring around the ignition and swap the chip from the key i have to the new one.. will i be ok ?
Citroen saxo ignition barrel
- x 6945
Re: Citroen saxo ignition barrel
The transponder coil around the ignition does nothing except energise the chip in the key or the fob and sends the signal to the Control Module. The Control module is a separate unit.
So replacing the ignition barrel should be straight forward.
Jonathancilia
- x 9
Ok then good, ill source a new ignition barrel and change it, thanks
