407 Rear Wheel Bearing
moizeau
x 423
Unread post by moizeau »
Could someone confirm that this is the correct part please?
https://www.piecesauto24.com/ridex/7999687
I've got an airplane in the rear right corner......
Pete
x 6945
Re: 407 Rear Wheel Bearing
Can't help you with that link Pete as I'll only supply proper PSA part numbers - which in this case are:
The Kit is part (2), which includes 2, 3 & 4.
OEM original Part is: 374887, priced £111.44
Cheaper Peugeot Alternative is 1623942480, priced £53.09
moizeau
x 423
Thanks , that's the same part number.
Pete
