berlingo engie swap
berlinvan21
berlingo engie swap
Unread post by berlinvan21 »
hi i have just replaced my 53 plate berlingo 1.9 diesel engine with another exactly the same code engine i have plugged all the leads in and have double checked everything however the engine ids turning over ok but not firing . have i missed something or as i suspect does the diesel pump need recoding
moizeau
x 423
Re: berlingo engie swap
Unread post by moizeau »
Unscrew an injector pipe very slightly and spin the engine. This will purge air from the pipes. Does any fuel appear? Did you swap the pump from the original engine? I believe these on a DW8 1.9 are armoured around the stop solenoid as an anti theft. If you have the old pump refit it. I don't think they can be recoded but can be de armoured but it is tricky in situ.
Pete
x 1061
Unread post by wheeler »
The pump is coded.
You have a few options.
Fit your original pump to the new engine.
Fit the BSI & transponder chip from the donor engie.
Or de armour the pump & fit a normal single wire solenoid.
berlinvan21
thanks
