Hi All
My passenger side wing mirror seems to have stopped working properly. When locking/unlocking it moves but only around 10% of the angle the drivers one does. I've tried to manually help it along and this helps it fold but has not sorted the issue. Any ideas on a proper fix or is it one for the garage? There must be a way to reset it somehow?
Thanks in advance for any assistance.
Jason
DS5 Wing Mirror issue
- x 6961
Re: DS5 Wing Mirror issue
There is no reset - it will likely be sticking due to lack of lubrication. Try using some silicon oil spray (not WD40!) in the mechanism where the mirror pivots. A few gentle sprays inside may help lubricate the plastic gearing.
It may take a few closing and opening actions to work through and this may then help. I would not recommend you force the mirror manually too often as you may disengage it (as in if it was hit by a vehicle) which knocks it out of the gearing mechanism and then can take a few attempts to re-engage again. Doing this too often can wear the gearing down.
It may also be that the gearing is too badly worn - so this fix may not work - and may appear to make the problem worse if it causes the gears to slip a bit more. this will eventually ease as the oil works in and through.
I've done this on the C3 and it cured the 'lazy mirror' foldback syndrome after a week of use - it went back to near normal.
Samsanda
Thanks Marc, really helpful! Will give it a go and let you know if it resolves the issue.
Cheers,
Jason
Cheers,
Jason
xsteel82
- New User
Hi People
I have the same problem with not folding mirror from passager side in my DS5. It is closing only about 10 % even less. The second one from driver is folding normaly. I had used oil in spray but was not help. Same glass - mirror is ok - full stering. Only folding doesn't work good. I think i have to disassemble the mirror to get to that mirror folding mechanism and then oil it. If that will not help maybe you have any sugestions what is going on ? I will write later. Thank you
- x 6961
In that case the motor has probably failed. Although Citroen do not supply motors, only the complete mirror unit according to model and options, one member has managed to source a motor - have a read of this thread:
viewtopic.php?t=72219
