12v Sockets not working
mrarg1393
Unread post by mrarg1393 »
Hello, I have a 2005 Citroen C5 (facelift version) and neither 12v sockets are working. I’ve checked the fuses which I assume are the correct ones from other replies on here, but the ones that need to be checked are absolutely fine. No breaks in them at all. I’m just a bit perplexed. I know the front socket is deep and I’ve managed to get a “deep” accessory plug in there but no life at all. Exactly the same as the centre console one too for the rear passengers. I don’t really fancy having to remove the dashboard to see what’s going on but if anyone could shed some light as to what it might be, it would be appreciated. Thanks!
x 6945
Re: 12v Sockets not working
Have you checked Fuse F38 in the BH12 fuse box in the glovebox. Be wary there are 2 fuse boxes with similar Fuse numbers - you want the one with the bank that has Fuses F36 to F40.
mrarg1393
Where abouts in the glove box is it? I can only see the one that you remove the cover off?
x 6945
You need to look along the sides, top and bottom to find them - they are usually attached to the main BSI board.
mrarg1393
Ah I’ve found it. I’ve checked it, replaced it but both still dead as a dodo. (Even with engine running)
x 6945
Pop your VIN up (automasked on post submission) and I'll take a look at the wiring diagram
mrarg1393
It’s VF7**************[VIN obfuscated, can be read by forum staff]
x 6945
Apart from that the front cigar lighter is fuse F9 in the BSI
mrarg1393
Just checked that and replaced it just in case but still nothing. I have no idea why it’s not working then… must be faulty wiring/connector to the actual socket possibly?
x 6945
I would be checking the live feed at the sockets (with ignition on) to see if you are getting power - if you are then I suggest that whatever devices have been plugged in have possibly damaged the socket. If that's the case they can be replaced easily enough.
