Citroen c5 x7 3.0 HDI active engine mounts
Falka
(Donor 2022)
x 5
Unread post by Falka »
Hello guys!
My friend asked me if i can dig up the installation / setup process of the active engine mounts. He said theres multiple nuts that needs proper torque or something like that :)
Do you guys have any documentation or info about this topic?
x 6945
Re: Citroen c5 x7 3.0 HDI active engine mounts
Here you go:
RH engine Support
ReferenceDesignationTightening torque ( daNm)
(1)Upper vibration damper (Right hand )2
(2)bolts / Right side upper engine mounting6
(3)nut / Right hand flexible engine mounting6,5
(4)bolts / Right-hand intermediate engine mounting8,2
(5)bolts / Engine suspension torque reaction rod6
(6)bolts / Right hand flexible engine mounting2,8
Front Piloted Torque Reaction Rod
(7)bolts / gearbox mounting (Front)6
(8)bolts / Front reaction link rod6
(9)bolts / Engine mounting seat (Front)6
Rear Piloted Torque Reaction Rod
(10)bolts / gearbox mounting (Rear )6
(11)bolts / Rear reaction link rod6
(12)bolts / Rear engine mounting6
(13)bolts / Torque reaction support link (Rear )6
LH Gearbox Support
(14)bolts / Gearbox vibration brace (Left hand )6
(15)bolts / Left hand flexible engine mounting6
(16)bolts / Left hand flexible engine mounting6
(17)bolts / LH upper engine mounting on gearbox5,5
Falka
(Donor 2022)
x 5
Thank you very much Marc!
Falka
(Donor 2022)
x 5
So i showed my friend this documentation. Sadly he wasn't specific enough about what he was stuck on. Apparently theres a few screw holes on the mounts, that (by design) has about 1-3cm "wiggle" room side to side. Probably to fine tune the mounts?
Hes asking, if theres any documentation about those or just "feel it out".
You cant really see it in the pic above, but i saw the mount brackets IRL, and they do have those "0" holes
