ds4 gearbox oil leak from small hole
r3ynolds
Unread post by r3ynolds »
Hi, whilst changing the brake pads on my daughters ds4 I noticed a small leak and tracked it to a small hole about 5mm perfect circle inside the area arrowed in pic. it is on the roof of that section should it be there? or should there be a plug of some kind in it, or its it damaged some how? (not actually gearbox) thanks in advance.
x 1055
Re: ds4 gearbox oil leak from small hole
Unread post by wheeler »
What is the last 8 digits of VIN or reg number & i can have a look & see if there is meant to be anything there.
r3ynolds
Hi, the last 8 ae DY524954 thanks
x 1055
Can you identify anything from these diagrams?
r3ynolds
Thanks for diagrams. no nothing on them indicate what the hole could be. the car will be at mine tomorrow so ill try getting a clear pic then.
Dormouse
x 696
Unread post by Dormouse »
the hole you have marked is right below the bolt on gear selector mechanism. A better diagram might be "gear selector" if there is such thing. If this is not a weep hole for a faulty gasket joint then it must be for some kind of sprung ball otherwise why would the case have this casting? I am really curious to see what it is.
r3ynolds
heres a pic of the hole. yes Dormouse there is a bolt direct above it for engine mount. this is def where the oil is coming from as there was a trail from it when i first look.
