Peugeot 3008 Hybrid (2012) unclear error
j07129120
Unread post by j07129120 »
Hi All,
Hope you are doing well under this extraordinary situation.
There is an annoying unsolved issue with my Peugeot 3008 Hybird (2012) for almost 2 year.
The symptom comes as follows: "Sometimes" an error message pops out when the car is just ignited or when the car is driven under a slow speed. Stopping the car right away and re-igniting won't remove this error. The translation of the error msg is something like "motor failure: stop the car urgently" as attached. (I bought this car from a friend in Germany).
My observation: When the error shows up, the driving power from the engine doesn't work anymore, and therefore the only source to drive the car became only the hybrid battery, and generally the car can't accelerate above 50 km/h. After driving for around 1-2 km flat road , the battery will run out of capacity. At this point if I switched off the car and re-ignite it, the error message will disappear and suddenly everything became just fine. The car can work just perfectly for the remaining of the day.
So far, I've visited 3 garages from the original Peugeot dealer and 2 private garages. Had many parts replaced but this issue still exists like a nightmare.
Now I am arranging another visit to the garage but I am feeling nothing but frustrated...
Have any of you met the similar issue with your car before? Do you have any suggestion I should ask the garage to inspect first?
I am not a native speaker and apologize if my word is unclear.
Best wishes, Tsung-Wei
x 6948
Re: Peugeot 3008 Hybrid (2012) unclear error
The translation is "engine fault have the vehicle repaired".
We can't really help without any fault codes - and if you have already taken it to Peugeot, I suggest you take it back to them. The speed limitation will be because the engine ECU has limited the power because of a certain fault / condition. Without knowing the actual fault then you will be changing parts needlessly as you have found out. If you have paid a dealer to diagnose the issue, then they should be able to tell you what is wrong with it.
Dormouse
x 696
Unread post by Dormouse »
When the "Engine Repair" warning light comes on is it only Amber (yellow) or go Red? Have any other amber warning lights come on either on their own or with the Engine warning? Your picture shows Amber but has it ever gone Red.
Dormouse
x 696
Marc is right -= you need the fault report from your Peugeot dealer. If they say it is not available that is not true. Their test machine generates and stores "Reports" for all test sessions and can be printed out at the press of a button. Don't get fobbed off or charged extra.
DimKar
Unread post by DimKar »
My personal experience says that this might be a result of the DPF filter. At 180.000 km it makes it without any notice. Look at it. Check. It' s expensive enough so try to find expert factories to clean it and take a guaranty.
