Hi
Bensonp
Hi
Unread post by Bensonp »
Hi and thanks for the add :) having a few issues with the car at the moment and was wondering if any one could run a diagnostic on it, Widnes area but don’t mind travelling.
The main issue is with the parking sensors just need to identify which one as failed
Citroen Picasso II 2017 model
Kind Regards and thanks in advance
Paul
x 8166
Re: Hi
Hi Benson and :welc: to the forum,
I am too far away from you really to help but there are members in your area with diagnostic equipment so I expect one of them will pop up soon. While you are waiting have a look round the forum from the Board Index above. There is a wealth of information, advice, entertainment and amusement to be found, mostly in the Off Topic Chat Lounge (OTCL) so have a nose and join in anything that takes your fancy. Good luck with the parking sensors. :)
x 3298
Re: Hi
Hi, and :welc: to the forum.
One way that MAY work is, when the parking sensors are active (but the car cannot move) carefully touch a lightweight screwdriver to each sensor. You should feel a vibration from each working sensor, and nothing from any that are not. This does NOT mean that a sensor has failed, merely that it is not working. It is not unknown for there to be a wiring failure in the sensor loom.
Bensonp
Re: Hi
Thanks for the warm welcome and look forward to using the forums. With regards the parking sensors i understood that when the car had a issue with any of the sensors it switched the system off and displayed the fault. With the parking sensors issue it also disables the self park and blind spot options. I did try various options to listen to each sensor however it appeared none of the front or back sensors were active making it more difficult to fault find :)
Thanks again
