Citroen parts
Estate87
(Donor 2021)
Citroen parts
Unread post by Estate87 »
Afternoon all
Apart from a Citroen dealer where is the best place to buy genuine parts?
I'm after a drivers side front window switch assembly. I'll probably end up having to use a dealer anyways because they'll need my vin number but I thought I'd ask.
Cheers
admiral51
(Donor 2026)
x 392
Re: Citroen parts
Unread post by admiral51 »
post your vin up and someone will be able to identify the correct part number.
As a donor i would put the vin in your signature that way Admins can see it and not need to ask for it :)
Colin
x 6947
Re: Citroen parts
Hi as you are a donor, pop your VIN - which we need for parts anyway (auto masked from public view on post submission). I can then get you the correct part number, from which you may be able to source an alternative genuine part from a dealer having a clear out (ebay and the like). Bear in mind that you won't always be able to get genuine parts elsewhere as they are specially made for the manufacturer in may cases.
Some parts are used across the PSA marques, and some are international parts that are common amongst other car manufacturers like engine sensors and components. Electrical ECUs tend to be more specialised though.
But you will at least need the original part number to start with and for that I need your VIN.
Estate87
(Donor 2021)
Re: Citroen parts
GiveMeABreak wrote: 28 Mar 2021, 17:38 Hi as you are a donor, pop your VIN - which we need for parts anyway (auto masked from public view on post submission). I can then get you the correct part number, from which you may be able to source an alternative genuine part from a dealer having a clear out (ebay and the like). Bear in mind that you won't always be able to get genuine parts elsewhere as they are specially made for the manufacturer in may cases.
I'll grab the vin tomorrow and attempt to auto mask it? I'm not 100% sure if I know how to do that.
Cheers
x 5677
Re: Citroen parts
Estate87 wrote: 28 Mar 2021, 20:03
Cheers
You don't need to do anything, just enter your VIN and the forum software masks it automatically.
x 3298
Re: Citroen parts
For example; VF7**************[VIN obfuscated, can be read by forum staff] (I just entered the characters V, F, and 7 to demonstrate the auto-mask function).
Estate87
(Donor 2021)
Re: Citroen parts
myglaren wrote: 28 Mar 2021, 20:04
Cheers
So enter my vin on a reply and it'll mask it? Sorry I'm not very forum savvy.
Cheers
x 5677
Re: Citroen parts
Estate87 wrote: 28 Mar 2021, 20:26
Cheers
Cheers
Yep, simple as that.
Estate87
(Donor 2021)
Re: Citroen parts
myglaren wrote: 28 Mar 2021, 20:37
Cheers
Brilliant I'll do that tomorrow morning.
Cheers
x 3298
Re: Citroen parts
What is the problem with the original assembly? If it is because it does not manage some of the windows properly you might want to just open it and clean the various contacts. I had (on my first C5) a couple of windows not responding properly, I cleaned the contacts, and the windows worked properly. Steve (Trainman) had the same problem, and he cleaned the contacts as well, and his windows worked properly.
Estate87
(Donor 2021)
Re: Citroen parts
Hell Razor5543 wrote: 28 Mar 2021, 21:07 What is the problem with the original assembly? If it is because it does not manage some of the windows properly you might want to just open it and clean the various contacts. I had (on my first C5) a couple of windows not responding properly, I cleaned the contacts, and the windows worked properly. Steve (Trainman) had the same problem, and he cleaned the contacts as well, and his windows worked properly.
It's stopped operating the wing mirrors properly, I replaced it with another assembly, all be it 2nd hand and now it's even worse. The wing mirrors had stopped dropping when the car is in reverse.
Am I chasing the wrong part being faulty or is this a good place to start?
Cheers
x 3298
Re: Citroen parts
I would still try cleaning the contacts (on the original module, if you still have it) before buying a new unit from Citroen. Make sure to use a PROPER contact cleaner to do the job. The modules are not difficult to open. You are removing the plastic 'plate' where the cables plug in. Care and a small blade screwdriver should do the job of opening it up.
x 5677
Re: Citroen parts
I had the same, the second time the membrane had expanded and the mirrors were a nightmare to operate and never had a full range of movement. I was intending to replace it but then scrapped the car - not because of than of course.
Estate87
(Donor 2021)
Re: Citroen parts
Hell Razor5543 wrote: 28 Mar 2021, 21:23 I would still try cleaning the contacts (on the original module, if you still have it) before buying a new unit from Citroen. Make sure to use a PROPER contact cleaner to do the job. The modules are not difficult to open. You are removing the plastic 'plate' where the cables plug in. Care and a small blade screwdriver should do the job of opening it up.
Perhaps I'll try cleaning up the connections on this assembly as I through the other one away.
I'll sure to put my vin up and get some clarification of the part though also.
Cheers
Estate87
(Donor 2021)
Re: Citroen parts
Morning all
My VIN is VF7**************[VIN obfuscated, can be read by forum staff].
Cheers
