DS5 Electronic engine Immobiliser fault
malecw89
how i can fix or who can fix it ? its happen after sterring column replace , but i put my old sterring electric lock
Reason: Please don't duplicate posts - it causes confusion and duplicate posts. I have deleted your other thread in the Diagnostics Section.
- x 6956
Re: DS5 Electronic engine Immobiliser fault
What actual parts did you replace? If you also replaced the Com 2008 unit inside the steering wheel (that holds all the lighting and wiper stalks), then that may be one reason, as these are different depending on features and options as well as build date. This is important as some units were hands free starting and some weren't and these had different com units.
malecw89
Sterring column with locker been replaced looks now like immobilizer is blocked
- x 6956
That's why I asked you exactly what has been replaced. The electronic module behind the steering wheel is specific to the vehicle and is responsible for handling the immobiliser data and communicating this to the BSI. SO if you have replaced that unit, it may be the incorrect one for your vehicle.
Example this is the unit I am talking about:
malecw89
Only this , after i was put my one but immo was block any chance to unblock by lexia diagbox i was ordered from ebay or enyone can help
- x 6956
That grey box is the electronic immobiliser that locks the steering wheel. If it is removed and refitted it needs re-programming.
malecw89
Then need to use lexia yes ? Any solution how to do it ? Am awaitig for diagbox lexia software
- x 6956
I can't help on this one, sorry, you'll have to run a Global Test and see if you can identify the unit from the list, just be careful to make notes and don't change anything that you are not sure of, as there is no backup! Take notes of any settings before you do anything.
malecw89
I have diagbox installed but cannot find vin becose there is no ignition i hear like try to connect t but nothing
- x 1056
Not sure i understand but can you not bypass the auto detection & enter VIN manually?
not had much dealings with the proximity key systems & electronic steering locks on these cars.
malecw89
was sorted.. needed new electric wheel steering lock from dealer , can be programmed once .
- x 6956
Thanks for the update - it's probably like the transponder chips in the fob - which can also only be programmed once - makes sense.
Edson Achaca
Good day does anyone have a picture of a Citroën electronic engine immobiliser?
- x 6956
There isn’t such a thing - an immobiliser is a descriptive term to denote the particular system used, which is made up of multiple components depending on what vehicle, electronic architecture and options you have fitted.
For example, there can be an electronic steering wheel lock or a manual lock with a key, then there is the transponder system incorporating receiver aerials and transmitters, immobiliser chips in the key fobs, all of which work together with the BSI and the Engine ECU to authorise vehicle unlocking, and starting.
So you’ll have to be a bit more specific as to what you are referring to.
Edson Achaca
I have a 2012 Citroën DS5 that is at one of Citroën dealership in South Africa and they said there is a problem with my electronic immobiliser and the part number is 9815905380 but they don’t have stock in the country and the ETA 23/01/2023 can anyone help me find this part? I can’t find it online.
