C5 Ser.1 passenger door won't open
aramsay
Unread post by aramsay »
I have an '02 / Ser.1 C5 and the front passenger door won't open.....when unlocked, either from inside
or outside.
About a year ago, it started playing up and sometimes not opening from the inside, so had to put the window
down and open from outside. The handle has very little resistance, and no "clicks".....
Any suggestions what has gone wrong, and how I might open the door to strip it for any work ?
Thanks.
Alan.
x 1056
Re: C5 Ser.1 passenger door won't open
Unread post by wheeler »
When you operate the central locking can you hear the motors operating? If you can’t try thumping on the outer door skin when operating the locking, sometimes this just gives it that extra lease of life to get the door open.
If the motors are operating you will need to get the door panel off to have a look what’s going on & check rods/cables are still attached etc. If you cant get the door open you will need to remove the seat to get the panel off im afraid.
x 1931
Unread post by Paul-R »
Also, try locking the vehicle with one door deliberately left open. The bounce back of the locking mechanism can sometimes loosen a stubborn lock mechanism off.
aramsay
Thanks for the suggestions.
When I eventually get the door open and stripped, is there anything that can be cleaned / freed-off,
or is it replacement job ?
One thing I should have mentioned....on the driver's door now, when you pull the handle, nothing seems to a happen sometimes. I normally have to push in the top of the door-frame, and pull handle at same time. It's as if the catch the handles operate are worn..... This was also an initial symptom on the passenger side.
Alan.
x 3302
On my current C5 the driver door played up a bit (and, on a couple of occasions, wouldn't open from the outside). Using the tube the can came with, I sprayed some 3 in 1 oil into the lock (and, when it opened, the latch mechanism). So far she has not done it again.
x 2941
Mine does the same at times, a squirt of 3in1 oil is usually enough to fix it, I take out one of the fixing screws and squirt through there.
Clogzz
x 40
Unread post by Clogzz »
Same here.
Had that several times over the years.
A good squirt of holy water has always fixed it.
GeorgeMeekins1993
Unread post by GeorgeMeekins1993 »
Maybe this knowledge will be useful for someone and this worked for me:
The first thing you need to do is remove the door upholstery you need to use a little strength and a foil, then unlock the clip from the plastic mounting the handle cassette. After unlocking move it towards the middle pillar or towards the front.
After unlocking, remove the cassette handle, then unscrew the torx screw holding the black plastic lock housing. From the cassette on the outside of the vehicle gently prise the plastic and you can see in the upper part of the lock levers and now you have to push the first one from the top towards the interior of the vehicle.
