Engine,gearbox,steering,braking faults on dash.
crapday69
(Donor 2017)
x 59
Unread post by crapday69 »
I was driving into work on Friday night when in the work car park my engine cut out and masses of faults came dinging up on my screen.
Engine. Gearbox. Steering and braking faults showed up. I plugged in my fault reader and 9 faults came up most about communications. I took the car to a local garage who seem to think it’s the DPF as it’s chock full. Could this result in all those faults. At first the aa and the garage thought it could be the alternator as a lie batter can cause faults like that.
Below is a couple of screen shots of the faults.
Thanks.
Gary.
x 1056
Re: Engine,gearbox,steering,braking faults on dash.
Unread post by wheeler »
So did the car restart again??
If it was an alternator fault the car should have restarted with a jump start & the alternator could have been checked.
I would also think that a DPF fault would have gave you plenty of warnings (limp mode, warning messages etc) before it got to the stage of making the engine cut out.
x 1921
Unread post by Paul-R »
What year is the car? How many miles has it done? Is it still on the original battery?
crapday69
(Donor 2017)
x 59
The car is a 12 plate with 117000 miles. It’s not the alternator that’s fine and the battery is healthy I replaced it 18 months ago. I was thinking the fuse box as I went through a big puddle the other week.
I’ve had no problems with lack of power or limp home mode. The car wouldn’t start but a couple of hours later it started but wouldn’t go into gear. When I turned the ignition off it wouldn’t start again. The heating fans also stopped working.
