Since a couple of weeks ago my back window wipers has stopped working. Nothing happens when I put the car in reverse (it usually wipes when put in reverse) and nothing happens when I turn the wiper switch on. There's no sound coming from the pump and there no washer fluid coming from the nozzle then I turn the switch all the way.
For the windshield everything works fine, both wipers and wash so I don't think there's something wrong with the pump nor the electronics in the switch.
I have tried swapping out the 15A fuse F1 in the dashboard fuse box, with a new one, with no luck.
I have noticed there's another fuse in the engine compartment (F3, 10A) that is assigned to the front/rear screen wash. Though it seems strange to me since the windshield wipers works perfectly...
Could that fuse be the problem or is there something else I could try to make the back window wipers work again?
Edit: changed engine compartment fuse box to dashboard fuse box
DS3 2011 rear window wipers/wash doesn't work
sebbDS3
- x 6963
Re: DS3 2011 rear window wipers/wash doesn't work
It might help if you pop your VIN up then I can see the electrical system for your car. Fuse F1 on the engine fusebox is a multifunction motor control.
The fuse for the rear wiper is located in the passenger compartment under the BSI - bottom row of fuses F1 - not the Engine Fusebox under the bonnet.
sebbDS3
My bad - I was too fast on the keys. I have swapped the F1 fuse in the dashboard fuse box, not the engine compartment fuse box, according to this diagram:
https://fuse-box.info/citroen/citroen-d ... 2016-fuses
- x 6963
Ok, to be sure, if you have your VIN handy I'll look up the electrical circuit to double check the fuse as they can vary.
sebbDS3
So the VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
- x 6963
The rear wiper motor is controlled by a relay on the BSI, but I would look at the connection to the rear motor first of all:
5215 is the rear motor. Pin 3 is the earth
521: Rear windscreen wiper motor command (Pin 1)
522: rear wiper motor fixed stop control (Pin 2)
The earthing point (MC60) is on the rear tailgate located below:
So I would check the plug connections there first of all and the condition of the pins and socket for damage or water.
