Hi all,
I drive a 2002 Citroen C8 and i need immo pin code, does anyone know how to get the pin by using my VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks,
Citroen C8 immo pin
- x 1056
Re: Citroen C8 immo pin
From the VIN its dealer only im afraid.
magnytic82
Other than that option?
- x 1056
Most auto locksmiths have tools that can extract the pin via OBD.
What do you need it for?
magnytic82
They try but cannot get it...maybe their tools not good enoughwheeler wrote: 17 Feb 2021, 07:59 Most auto locksmiths have tools that can extract the pin via OBD.
Engine immobilizer fault came up a few times but it now refuses to start, so I need to set configuration management.
- x 6957
I think you need a proper diagnosis first - you may just have a transponder coil or other electrical issue, which if this is the case, won't be resolved by changing your BSI configuration or changing any of the ECUs.
haksri
Hi! I need to stick code from EDC15C2 Citroen C8 eprom 95P08.
Reason: Removed Suspicious Links - Completely Unrelated
- x 6957
This is not something we can help you with here. As said in the thread, if it's a customer confidential code you need, you will need to speak to your dealer - if other then you'll need to speak to an engine ECU chip specialist / programmer.
