Hi all,
I drive a 2002 Citroen C8 and i need immo pin code, does anyone know how to get the pin by using my VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks,
Citroen C8 immo pin
- My Cars: Citroen BX 19GT
Citroen ZX Volcave
Citroen C8
Re: Citroen C8 immo pin
From the VIN its dealer only im afraid.
Citroen ZX Volcave
Citroen C8
Most auto locksmiths have tools that can extract the pin via OBD.
What do you need it for?
Citroen ZX Volcave
Citroen C8
They try but cannot get it...maybe their tools not good enough
Engine immobilizer fault came up a few times but it now refuses to start, so I need to set configuration management.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
I think you need a proper diagnosis first - you may just have a transponder coil or other electrical issue, which if this is the case, won't be resolved by changing your BSI configuration or changing any of the ECUs.
Hi! I need to stick code from EDC15C2 Citroen C8 eprom 95P08.
Reason: Removed Suspicious Links - Completely Unrelated
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
This is not something we can help you with here. As said in the thread, if it's a customer confidential code you need, you will need to speak to your dealer - if other then you'll need to speak to an engine ECU chip specialist / programmer.
