C5 X7 - Dead Battery - Locked out
chalkhills
(Donor 2021)
Unread post by chalkhills »
Hi - Anyone help?
Battery is flat and I can't access with the door key locks - they just turn 90 degrees each way and nothing happens.
Thanks in advance!
Dave
x 3296
Re: C5 X7 - Dead Battery - Locked out
Try a shot of 3 in 1 oil into the locks (using a pipe to get INTO the lock and not get deflected by the weather guard). Give it a few minutes to soak in, and then try with the key. Poundland do small spray cans of 3 in 1 oil with the pipe mentioned.
x 6945
Are you sure you tried turning the key in the lock and then tried opening the handle then try it the other way? Don't expect all the doors to open - but it should open the driver's door.
My tip is in these sorts of conditions where the car is not being used for a week or longer in these sorts of conditions is to move the SHUNT fuse from Customer mode to Park mode, that will switch off more of the power consuming features when the car is locked. Just remember to move it back when the car will be used for normal commuting.
I know it doesn't help now though. Did you deadlock the car (2 presses on the key fob)? If so, the doors won't open via the internal door handles if this is the case as these handles are disconnected with deadlocking.
As the bonnet release is covered by the passenger door on the X7, there is no way to get to that either from the inside.
I'm wondering whether if you leave the car until things warm up, the battery may provide enough power to unlock the doors.
Some other suggestions here:
https://www.justanswer.co.uk/car/89ilv- ... onnet.html
chalkhills
(Donor 2021)
Yep - tried both ways - it doesn't feel as if anything is seized or slipping - both locks turn 90 degrees each way. I would have thought the drivers side at least would operate a mechanical lock as opposed to the electrical central locking switch only - anyone know if this is the case? I know my Mk1 C5 is definately a mechanical unlock mechanism.
Re. the deadlocking - I've no idea if I've double pressed it or not - it was a couple of months back (broke my ankle!)
I'm guessing the only option may be to jack it up (on the loose hardcore slope!), get undertray off and try and reach the (bonnet release) outer cable to give it a tug.
Anyone know if this is possible?
Or is there any accessable permanent +ve points (eg starter connection) I could get external supply to?
Dave
x 3296
If the key has not been used in the lock for a long while parts can stick, so the barrel can turn without engaging the mechanical parts, which is why I suggested the 3 in 1 oil (not normal WD40, which is a water dispersant).
chalkhills
(Donor 2021)
I'll go give them a squirt just now - Thanks. . . . .
chalkhills
(Donor 2021)
Hi Hell Razor - I know what you mean about the barrels turning round and round without engaging - my old Mk1 C5 used to do just that but these lock feel completely different and don't appear to be seized or stiff - as I said both locks turn against a spring 90 degrees each way without engaging a lock mechanism at all.
x 6945
I know when I had my battery off to charge it in the house, I locked the car manually using the key - a single turn in both front doors - I also remember using the physical key in the rear doors (using the special key access port after removing the plug near the child lock) to lock those manually.
So it should work - the only reason I can think for it not to is if the car has been deadlocked using the fob - maybe that has affected the keys ability to unlock it with the physical key - but I can't be certain.
There was some suggestions in that article I linked to near the end that talked about providing power to the battery via the alternator or starter - make sure you read the article to the end.
As far as the bonnet catch is concerned, there are 2 wires. The first is triggered from the bonnet release handle (now hidden by the passenger door) which releases the bonnet from the lock and the second pull on the plastic tab obviously releases the bonnet fully. Whether you can even get to the secondary wire with a long screwdriver with the bonnet unreleased at the first stage I can't say. I know it was a job when I had to replace the bonnet release wire and tab a few winters ago when the plastic tab became brittle and snapped. I managed to release it with a long screwdriver - but only after the bonnet has been released from inside first of all.
I think your best bet is from underneath - but do support the car in case the suspension drops suddenly - which it can do! Once you take of the under tray protection, you may see a way.
Have a look at my brief video of the second wire operating after I replaced the catch - it may give you a visual clue:
chalkhills
(Donor 2021)
Thanks Mark - that really helpful! It looks like there is a reasonable amount of room around the engine to get to stuff from below.
Dave
x 6945
That's what I thought - one thing about the X7 is that on these engine bays there's room for a barbecue in there.
